Script to add Computers to Static Group by Computer Name
Show first post
  • June 3, 2019
If you receive "0 computers matched" "Attempting to upload computers to group x" -- With the result that no computers get added to the static group:
  • A possible solution is to ensure your input file does not contain any extensions (.txt) in the filename!
  • 13 replies
  • October 20, 2019
Thank you @alexjdale and @cshepp11 , for sharing this script. I was able to make half way.
Do you also have script to remove computers from static group? Please share with me if you got one ready.
I was trying to modify the given script to remove computers in it but it was deleting the static group itself.
Thank you.
sdagley
  • 3543 replies
  • October 21, 2019
@Naren Take a look at the thread Script to add a device to a computer group? for an example of how to add a computer to an existing Static Group rather than replacing the contents of the group. Following the example in that thread you can use computer_deletions instead of computer_additions to remove computers from a group instead of adding them.
  • 13 replies
  • October 30, 2019
Thank you @sdagley for sharing the link. I was trying with two different scripts one to add multiple computers to static group other to remove from static group.
But when i was trying to execute the script it is adding or removing only the last entry from excel.
For example my .csv file has four computers and script is actually only reacting to the last one in it. @cshepp11
!/bin/bash
currentuser=$(stat -f%Su /dev/console)
HostName=$(scutil --get ComputerName)
logdir="/Users/${currentuser}/Desktop/AdminExceptions.csv"
Verify input file exists
if [ ! -f "${logdir}" ]; then echo "Input file not found, exiting" exit 1
IMPORTLIST="${logdir}"
EXPORTFLAG=€1.80
exportCSV="/tmp/JSSFailures.csv"
Hostname of JSS
JSS="jssportal.com"
Group ID for target static group
JSSGROUPID="53"
JSSGROUPNAME="AdminRightExceptions"
API service account credentials
JSSUSER="apiuser"
JSSPASS="apipwd"
Start building XML for computer group, which will be uploaded at the end
GROUPXML="<computer_group><computer_deletions>"
if [ ! "$JSS" ] || [ ! "$JSSGROUPID" ] || [ ! "$JSSUSER" ] || [ ! "$JSSPASS" ]; then echo "Required variables have not all been entered. Please validate and retry." exit 1
echo "Input file: ${logdir}"
Read list into an array
inputArraycounter=0
while read line || [[ -n "$line" ]]; do inputArray[$inputArraycounter]="$line" inputArraycounter=$[inputArraycounter+1]
done < "$IMPORTLIST"
echo "${#inputArray[@]} lines found"
foundCounter=0
for ((i = 0; i < ${#inputArray[@]}; i++)); do echo "Processing ${inputArray[$i]}" nameLookup=curl -s -k -u $JSSUSER:$JSSPASS https://$JSS:8443/JSSResource/computers/name/${inputArray[$i]} sizeLookup=echo $nameLookup | xpath //size 2>/dev/null | tr -cd [:digit:] if [ "$sizeLookup" != "" ]; then idLookup=echo $nameLookup | xpath //id 2>/dev/null if [ "$idLookup" ]; then GROUPXML="$GROUPXML<computer>$idLookup</computer>" foundCounter=$((foundCounter+1)) fi echo "Match found, adding to group"
else echo "$sizeLookup entries found, skipping." if [ "$EXPORTFLAG" = "export" ]; then echo "${inputArray[$i]},$sizeLookup computers matched">>$exportCSV fi fi
done
GROUPXML="$GROUPXML</computer_deletions></computer_group>"
echo "$foundCounter computers matched"
deleting computer from casper with UUID
echo "Attempting to Delete computers from group $JSSGROUPID"
curl -s -v -k -u $JSSUSER:$JSSPASS https://$JSS:8443/JSSResource/computergroups/id/$JSSGROUPID -X PUT -HContent-type:application/xml --data $GROUPXML
@sdagley any idea why its picking up only last line in the lookup, for example if I have 3 values, a, b, c in the list it will only process value c and leave other 2 items?
  • May 3, 2021
Hey, in order to run script in Big Sur, use xpath5.18
# Copyright 2014 by Alex Dale
# Add computers to a static group in a JSS from a plaintext list of computer names
# Make sure your target group is a static group and is empty, or it will be overwritten
# Input file must have one name per line.
# Usage: scriptname.sh /path/to/input/file
# Add "export" as an optional argument after input file to export a csv with failed system lookup info to /tmp/JSSFailures.csv
# Searches are performed with a wildcard at the end to catch names with (2), etc appended to the name by the OS
# Multiple matches (due to wildcard or dupe records) will be skipped, for safety
# Test this first on your dev JSS!  I cannot account for all scenarios.
#Verify input file exists
if [ ! -f "$1" ]; then
    exit 1
IMPORTLIST=$1
EXPORTFLAG=$2
# Hostname of JSS
JSS="jss.domain.com"
# Group ID for target static group
JSSGROUPID="inputyourgroupidhere"
# API service account credentials
JSSUSER="username"
JSSPASS="password"
# Start building XML for computer group, which will be uploaded at the end
GROUPXML="<computer_group><computers>"
    exit 1
echo "Input file: $1"
# Read list into an array
inputArraycounter=0
foundCounter=0
    nameLookup=`curl -s -k -u $JSSUSER:$JSSPASS https://$JSS:8443/JSSResource/computers/name/${inputArray[$i]}`
    sizeLookup=`echo $nameLookup | xpath5.18 //size 2>/dev/null | tr -cd [:digit:]`
        idLookup=`echo $nameLookup | xpath5.18 //id 2>/dev/null`
            foundCounter=`expr $foundCounter + 1`
done
GROUPXML="$GROUPXML</computers></computer_group>"
echo "Attempting to upload computers to group $JSSGROUPID"
curl -s -k -u $JSSUSER:$JSSPASS https://$JSS:8443/JSSResource/computergroups/id/$JSSGROUPID -X PUT -HContent-type:application/xml --data $GROUPXML
Cookie policy
Cookie settings
