Can you post a copy of your script and any errors you may be getting?
This is the Sentinel One script I use in an Extension Attribute.
if command -v sentinelctl 1>/dev/null; then
echo "<result> SentinelOne agent is installed with version
`sentinelctl version | awk '{print $2}'` and was connected to management
console `sentinelctl config Server Address | tail -1 | awk '{print $2}'` </result>";
s1_agent=$(ps aux | grep -Ei "sentineld$" | awk '{ print $11 };' |
grep -v grep)
if [ -z $s1_agent ]; then
echo "<result>SentinelOne Agent is not Installed.</result>";
s1_agent=$(echo $s1_agent | sed 's|sentineld|
sentinelctl|g')
echo "<result>SentinelOne Agent is running but
could not locate SentinelCtl in the default PATH /usr/local/bin. The full path is - $s1_agent </result>" ;
