simple syntax terminal command question
I am trying to clean up the results that report back on my EA. I am sure this is something simple but my eyes are getting cross-eyed trying to get the correct syntax.
I have an EA that reports back the board-id of the systems.
echo "<result>$(ioreg -p "IODeviceTree" -r -n / -d 1 | grep "board-id")</result>"
reports back "board-id" = <"Mac-6F01561E16C75D06">
To delete the "board-id" = I added the | awk '{print $3}'
echo "<result>$(ioreg -p "IODeviceTree" -r -n / -d 1 | grep "board-id" **| awk '{print $3}'**)</result>"
reports back **<"**Mac-6F01561E16C75D06**">**
To delete the "" I added the | sed s/"//g
echo "<result>$(ioreg -p "IODeviceTree" -r -n / -d 1 | grep "board-id" | awk '{print $3}' **| sed s/"//g)**</result>"
reports back **<**Mac-6F01561E16C75D06**>**
To delete the < I added the | sed s/<//g
echo "<result>$(ioreg -p "IODeviceTree" -r -n / -d 1 | grep "board-id" | awk '{print $3}' **| sed s/<//g**)</result>"
reports back **"**Mac-6F01561E16C75D06**">**
To delete the < & " I added the | sed s/<"//g
echo "<result>$(ioreg -p "IODeviceTree" -r -n / -d 1 | grep "board-id" | awk '{print $3}' **| sed s/<"//g**)</result>"
reports back Mac-6F01561E16C75D06**">**
I cannot get the syntax correct to report without <" & ">
What I want it to report back is Mac-6F01561E16C75D06
Best answer by localhorst
Have you considered replacing awk with the only true script language?
  perl -n -e '/board-id.*<"(.*)">.*/ && print "<result>$1</result>
HTH?
Marko
  • 50 replies
  • January 29, 2014
HTH?
Marko
  • 52 replies
  • January 29, 2014
Thanks Marko, you are the best.
  • 7883 replies
  • January 29, 2014
Or, you could stick with awk and use awk's special multi character field separator in combination with its regex matching to print only the text between the second set of "s
echo "<result>$(ioreg -rd1 -c IOPlatformExpertDevice | awk -F'["|"]' '/board-id/{print $4}')</result>"
<result>Mac-94245B3640C91C81</result>
  • 7883 replies
  • January 29, 2014
Dreaded double post...
  • 54 replies
  • January 29, 2014
I got it working by substituting sed with tr
$ ioreg -p "IODeviceTree" -r -n / -d 1 | grep "board-id" | awk '{print $3}'| tr -d "<>
Cookie policy
Cookie settings
