Posted on 04-26-2018 09:46 AM
I made a script to help me check if any of our computers are eligible for this program. I hope it can help others too.
https://www.apple.com/support/13inch-macbookpro-battery-replacement/
import requests
import lxml.html
import csv
# python 3.4
# 13-inch MacBook Pro (non Touch Bar) Battery Replacement Program
# based on https://www.apple.com/support/13inch-macbookpro-battery-replacement/
# using csv file from export feature of jamf
# format of csv file: Computer Name,Total RAM MB,Operating System Version,Drive Capacity MB,Battery Condition,DA Asset Tag,Last TM Backup,Serial Number,Model,Managed,Last Check-in,
# use at your own risk
# YMMV
not_eligible_count = 0
eligible_count = 0
total_items = 0
def eligible_for_battery(serial_number):
global not_eligible_count
global eligible_count
global total_items
url = 'https://www.apple.com/support/13inch-macbookpro-battery-replacement/'
form_data = {
'ihc_textbox': serial_number,
'ihc_submit': 'Submit',
thing = False
while thing is False:
response = requests.post(url, data=form_data)
if response.status_code == requests.codes.ok:
total_items += 1
thing = True
else:
thing = False
tree = lxml.html.document_fromstring(response.content)
is_not_eligible = tree.body.get_element_by_id('ihc_E01')
if is_not_eligible is not None:
not_eligible_count += 1
return not_eligible_count, serial_number
eligible = tree.body.get_element_by_id('ihc_E00')
if eligible:
eligible_count += 1
return eligible.text, serial_number
else:
print("something didn't work right")
def check_against_jamf():
global total_items
rowcount = 0
csvfile = 'allcomputersjamf.csv'
datafile = open(csvfile, 'r')
csvreader = csv.reader(datafile)
for row in csvreader:
eligible_for_battery(row[7])
rowcount += 1
print("eligible: {}, not eligible: {}, total devices checked: {}, rows in csv: {}".format(
eligible_count, not_eligible_count, total_items, rowcount))
if __name__ == '__main__':
