Posted on 12-19-2014 01:42 PM
Hello,
I'm trying to create a policy that only grays out the policy tab in system preferences. I have that working except that it seems to gray out all other 3rd party system preference panels, except the ones that are explicitly included in the JSS (i.e. java control panel).
We have several people that use programs like Hazel that require a system preference panel, and I can't figure out how to make it so ONLY the profiles pane is blocked. Any ideas?
Solved! Go to Solution.
Posted on 12-19-2014 01:49 PM
If you're using configuration profiles, you can make a custom configuration profile on an OS X client running Server.app V3 or above and then import it into the JSS for distribution. Just make sure the panes you want to show up are also installed on this client. So using Hazel as an example, make sure it's installed on the client you use to make the custom configuration profile.
Posted on 12-19-2014 01:54 PM
beaten to the punch.
It is a configuration profile. I'll try making it through server and uploading it instead of creating it on JSS. Thanks!
Posted on 12-19-2014 01:55 PM
hkabik that's what it says, but it only applies to built in system preferences. All 3rd party ones (except the two that JSS shows) are automatically blocked out in addition to anything you manually check the box for.
Posted on 12-22-2014 05:59 AM
https://jamfnation.jamfsoftware.com/article.html?id=204
