Posted on
08-20-2016
07:57 AM
- last edited
3 weeks ago
by
kh-richa_mig
According to Adobe's systems requirements page for Captivate 9.0.2, the minimum system version is 10.11.6
According to Adobe's systems requirements page for Captivate 9.0 and 9.0.1, the minimum system version is 10.10.3
Release note for 9.0.1 and 9.0.2 both point to the 9.0.2 systems requirements page.
Looping in @kagibson to see if knows who heads up that group. We have a lot of users who are requesting it. So would be beneficial to all parties to get these details ironed out at the Adobe site. :)
@kagibson does 9.0.2 really raise the system requirement to 10.11.6?
PS, please keep the Adobe DC team away from the Adobe Captivate team...that last thing we need is a dev team to screw up standard versioning as they did with the DC product. ¯_(ツ)_/¯
Thanks,
Don
Posted on 08-22-2016 02:19 AM
Sounds like a mix-up between "Minimum Requirements" and "is Compatible With"
Posted on 08-27-2016 12:01 AM
Well, let's see if they respond to my Adobe forum post.
Posted on 09-04-2016 07:19 PM
No response to the thread at the Adobe forum. ¯_(ツ)_/¯
Posted on 09-07-2016 02:07 PM
Ok, so Adobe just alienated their entire customer base.
They just merged both KB articles, and raised the minimum OS requirement to 10.11.6.
Believe it. You can't make this s**t up.
Don
Posted on 09-17-2016 11:47 AM
Adobe's lack of oversight continues...
