Adobe creative suite color settings.
rdagel
New Contributor II
We like to preset the color settings for the creative suite for color
management. When we make a package for deployment the settings do not seem
to stick. Has anyone had this issue?
Thanks
Rich
1 REPLY 1
Not applicable
Rich,
Just to make sure I'm understanding your question...are you talking about
color setting within individual applications? If so, I have done this before
for CS and CS2 for Photoshop and Illustrator and typically works fine.
Which OS are using? Panther or Tiger? If Panther, if I'm not mistaken you
may want to log out and back in before you build your package.
Zach, JAMF Support, correct me if I'm wrong.
Cyrus
