An exception of class NilObjectException was not handled FIX
Error: An exception of class NilObjectException was not handled. The application must shut down.
Scenario: I was uploading the following file, using Jamf Admin, and it failed every time: Install macOS Big Sur.app.pkg
Fix/Solution: Rename the file, the extra dot is causing the error
TO: Install macOS Big Sur app.pkg (REMOVED dot before "app")
NOTE: This error and solution may not help you. Other scenarios could also cause this.
Also tried (non worked):
- Updating file through Jamf Pro --> Settings --> Packages --> New Package --> Upload --> would not upload at all
- Updating Jamf Admin
- Changing file permissions
  • 7 replies
  • May 11, 2021
Thanks, that was my issue too.
rstasel
  • 334 replies
  • June 10, 2022
Just ran into this. it's specifically .app or in my case, .apps. =(
PoisonApple
  • 5 replies
  • February 6, 2023
Does anyone have a fix for this? I am having the same issue
rstasel
  • 334 replies
  • February 6, 2023
Does the pkg you’re uploading have “.app” in the name?
PoisonApple
  • 5 replies
  • February 6, 2023
No, I have tried with .apps I repackaged as .pkg, regular .pkg and .dmg – with different errors it turns out something is wrong my copy of Jamf Admin, it works fine on another system. Thank you for the reply!
rstasel
  • 334 replies
  • February 6, 2023
Cool, thanks!
Cookie policy
Cookie settings
