Anyone know how to create a smart group of users with multiple computers
  • 19 replies
Hopefully its not something easy that I overlooked, but the goal here is to see if a user/how many users have multiple computers so that we can delete from JSS (assuming we forgot to do it earlier or missed it).
we cant delete based on last check in since some users are remote and will probably never VPN or come on-campus again.
Our JSS is also NOT externally facing so there's that.
any thoughts?
thanks!
rqomsiya
  • 225 replies
  • February 1, 2018
Is this something that is a recurring issue for you?
Why not just do an advanced search and check the XLS output?
  • 117 replies
  • February 1, 2018
instead of deleting them and not being sure, why not just unmanage them? This way you keep a record of the device and it doesn't count against your seats.
Cookie policy
Cookie settings
