Posted on 02-18-2019 02:26 AM
I before used msupdatehelper in 2016, but now in 2019 it seems to be broken(even I changed the identiiers to 2019 in the script) ?
When fx trying to upgrade a old 2016 version like 15.39 and running MAU 4.8 and doing a msupdate -i the latest 16.22 updates are not found but only older 16.16.x
Is there any trick to get this working again so I don´t have to send out updates in packages
EDIT: May @pbowden you have some input if this still should work - or what the best practise is to do?
Posted on 02-18-2019 03:55 AM
