Posted on 03-11-2013 02:05 PM
Can I set prefs from .GlobalPreferences.plist with config profiles? I tried the domain .GlobalPreferences and GlobalPreferences in a custom settings, but those did not work. There is a lot in there I need to set. I know defaults write NSGlobalDomain com.apple.swipescrolldirection -bool false works, but I need to set it with a config profile.
Posted on 03-11-2013 09:38 PM
Yes, and they work just fine.
See http://managingosx.wordpress.com/2013/02/05/disabling-icloud-as-default-save-location/
-Greg
Posted on 03-12-2013 05:26 AM
Thanks. It does look like it works. Just not for the key I was testing with com.apple.swipescrolldirection=false. Others do appear to stick. Anyone had any luck forcing com.apple.swipescrolldirection?
Posted on 05-08-2014 07:53 AM
Anyone successfully managing com.apple.swipescrolldirection=false via config profile ?
Saw this thread seemingly someone else (@rcorbin) looking for same info too https://jamfnation.jamfsoftware.com/discussion.html?id=4200
Posted on 05-08-2014 08:12 AM
I'd suggest using mcxToProfile and testing "Once" and "Often" frequencies; it's possible this preference can't be managed "Always".
https://github.com/timsutton/mcxToProfile
Posted on 05-08-2014 08:58 AM
thanks @gregneagle
Posted on 05-08-2014 06:04 PM
I'm pretty sure .GlobalPreferences was designed to be manageable only once or often.
