Appending to users PATH variable.
Hi All
Just looking for some guidance on the above. I have an application that I have packaged but it requires the users $PATH variable to be edited. Just wondering how to go about doing this. I don't want to export my packaging machines .profile and add it to the package for the users machines, as they might have variables written from other installations and I don't want to overwrite them.
So want to see if there is anything in the JSS that can possibly push out variables? We use DMG's in our environment so cannot run a post install script to add it. The users also want to use the application through command line from Terminal so I cannot even write a launcher.app to write the variable then launch the application.
So, does anyone have any ideas on how to handle user variables?
Thanks, Jim
Best answer by cvgs
Have a look at /etc/paths.d/, that should be all you need:
ls -l /etc/paths.d/ -rw-r--r-- 1 root wheel 107 7 Feb 22:49 com.apple.server
cat /etc/paths.d/com.apple.server /Applications/Server.app/Contents/ServerRoot/usr/bin /Applications/Server.app/Contents/ServerRoot/usr/sbin
  • 76 replies
  • May 10, 2013
  • May 10, 2013
Thanks a million, thats helped.
donmontalvo
Forum|alt.badge.img+36
  • 4293 replies
  • May 10, 2013
What about:
$ cat /etc/paths
/usr/bin
/bin
/usr/sbin
/sbin
/usr/local/bin
https://developer.apple.com/library/mac/documentation/Darwin/Reference/ManPages/man8/path_helper.8.html
Don
Cookie policy
Cookie settings
