- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 11-28-2016 05:50 PM
Hi, we are trying to add a status bar to one of our dialogs that pops up at login.
We use this for the status bar:
set n to 10
set progress total steps to n
repeat with i from 1 to n delay 1 set progress completed steps to i
end repeat
We use this for the text:
display dialog "..."
Unfortunately, we cannot seem to merge these two without breaking the status bar. Has anybody ever had success with this?
Thanks in advance,
Jared
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 11-28-2016 08:00 PM
Try this:
set n to 10
set progress additional description to "..."
delay 1
end repeat
You'll find some good documentation on Apple's Developer site. FYI, the status bar only appears for scripts saved as apps and then opened by double-clicking or using a File > Open command.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Try this:
set n to 10
delay 1
end repeat
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 11-29-2016 12:52 PM
@talkingmoose Thank you, exactly what I need.
