At Reboot Scripts not running No Helper screen
Hello,
I am running into a very odd situation. We recently purchased iMacs with Yosemite on them. I am attempting to provision them using Casper imager. The provisions is very simple since all my installation are done once the computer has been enrolled.
After "Prepare FirstRun Script" I have it set the name via CSV file (this is working). Create a local admin account (this is working. Then it runs a script to turn on remote management, set WiFi to our SSID, Sets Timezone, Spotlight fix, and Z Post imaging tasks. None of these scripts are triggering.
Also, when I reboot the machine, I never get the preparing for the first time message as I would before. One thing I do notice is the time is way off. Any ideas what might be causing this issue?
Be the first to reply!
Cookie policy
Cookie settings
