AutoPkgr Issues
Bobst
New Contributor
Started using AutoPkgr after the JNUC this year and I'm running into a problem where my smartgroup for any software isn't accurate. I created a static group called Testing put a couple computers in it and then I run the AutoPkgr it creates the group and the policy.
I followed all the instructions in Step 1 and Step 2.
Criteria for the smart group is: I Feel like %JSSINVENTORY_NAME% should be Firefox.app or any other recipe I'm running AutoPkgr on.
Application Title = %JSSINVENTORY_NAME%
Application Version = 33.0.2
Computer Group = Testing
Any help with be appreciated.
1 REPLY 1
elliotjordan
Contributor III
Hi @Bobst,
Is this still happening for you? I believe this may have been a bug that was squashed in a previous update of AutoPkgr/JSSImporter, but I wanted to check in to be sure.
Elliot
