Autoupdate Java by shell
peterlbk
Hi all!
inspired by the great @rtrouton , I adjusted his superb script on installing Java.
I added a check to see if java has been installed or if a newer version is available, a bit like my Flash Update script, for which I borrowed heavily on other guys work.
Hope you guys can use this, and if you have any suggestions, please let me know!
#!/bin/bash -e
# This script downloads and installs the latest Oracle Java 8 for compatible Macs
# Determine OS version
osvers=$(sw_vers -productVersion | awk -F. '{print $2}')
# Specify the "OracleUpdateXML" variable by adding the "SUFeedURL" value included in the
# /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Info.plist file.
# Note: The "OracleUpdateXML" variable is currently specified in the script as that for
# Java 8 Update 20, but the XML address embedded with Java 8 Update 20 is not special in
# this regard. I have verified that using the address for Java 8 Update 5 will also work
# to pull the address of the latest Oracle Java 8 installer disk image. To get the "SUFeedURL"
# value embedded with your currently installed version of Java 8 on Mac OS X, please run
# the following command in Terminal:
# defaults read "/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Info" SUFeedURL
# As of Java 8 Update 20, that produces the following return:
# https://javadl-esd-secure.oracle.com/update/mac/au-1.8.0_20.xml
OracleUpdateXML="https://javadl-esd-secure.oracle.com/update/mac/au-1.8.0_20.xml"
# check if newer version exists
plugin="/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Info.plist"
if [ -f "$plugin" ]
then
    currentver=`/usr/bin/defaults read "/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Info.plist" CFBundleShortVersionString`
    echo " Current version is $currentver"
    currentvermain=${currentver:5:1}
    echo "Installed main version is $currentvermain"
    currentvermin=${currentver:14:2}
    echo "Installed minor version is $currentvermin"
    /usr/bin/curl --retry 3 -Lo /tmp/au-1.8.0_20.xml $OracleUpdateXML
    onlineversion1=`cat /tmp/au-1.8.0_20.xml | awk -F " /enclosure/'{print $(NF-1)}'`
    onlineversion2=${onlineversion1:50:8}
    onlineversionmain=${onlineversion2:2:1}
    echo "Online main: $onlineversionmain"
    onlineversionmin=${onlineversion2:6:2}
    echo "Online minor: $onlineversionmin"
    if [ "$onlineversionmain" -gt "$currentvermain" ]
    then
        echo "Let's install Java! Main online version is higher than installed version."
        installjava=1
    if [ "$onlineversionmain" = "$currentvermain" ] && [ "$onlineversionmin" -gt "$currentvermin" ]
    then
        echo "Let's install Java! Main online version is equal than installed version, but minor version is higher."
        installjava=1
    if [ "$onlineversionmain" = "$currentvermain" ] && [ "$onlineversionmin" = "$currentvermin" ]
    then
        echo "Java is up-to-date!"
    echo "No java installed, let's install"
    installjava=1
# Use the XML address defined in the OracleUpdateXML variable to query Oracle via curl
# for the complete address of the latest Oracle Java 8 installer disk image.
fileURL=`/usr/bin/curl --silent $OracleUpdateXML | awk -F " /enclosure/'{print $(NF-1)}'`
# Specify name of downloaded disk image
java_eight_dmg="/tmp/java_eight.dmg"
if [[ ${osvers} -lt 7 ]]; then
  echo "Oracle Java 8 is not available for Mac OS X 10.6.8 or earlier."
if [ "$installjava" = 1 ]
then
    echo "Start installing Java"
    if [[ ${osvers} -ge 7 ]]; then
        # Download the latest Oracle Java 8 software disk image
        # The curl -L option is needed because there is a redirect
        # that the requested page has moved to a different location.
        /usr/bin/curl --retry 3 -Lo "$java_eight_dmg" "$fileURL"
        # Specify a /tmp/java_eight.XXXX mountpoint for the disk image
        TMPMOUNT=`/usr/bin/mktemp -d /tmp/java_eight.XXXX`
        # Mount the latest Oracle Java 8 disk image to /tmp/java_eight.XXXX mountpoint
        hdiutil attach "$java_eight_dmg" -mountpoint "$TMPMOUNT" -nobrowse -noverify -noautoopen
        # Install Oracle Java 8 from the installer package. This installer may
        # be stored inside an install application on the disk image, or there
        # may be an installer package available at the root of the mounted disk
        # image.
        if [[ -e "$(/usr/bin/find $TMPMOUNT -maxdepth 1 ( -iname *.app ))/Contents/Resources/*Java*.pkg" ]]; then
            pkg_path="$(/usr/bin/find $TMPMOUNT -maxdepth 1 ( -iname *.app ))/Contents/Resources/*Java*.pkg"
        elif [[ -e "$(/usr/bin/find $TMPMOUNT -maxdepth 1 ( -iname *Java*.pkg -o -iname *Java*.mpkg ))" ]]; then
            pkg_path="$(/usr/bin/find $TMPMOUNT -maxdepth 1 ( -iname *Java*.pkg -o -iname *Java*.mpkg ))"
        # Before installation, the installer's developer certificate is checked to
        # see if it has been signed by Oracle's developer certificate. Once the
        # certificate check has been passed, the package is then installed.
        if [[ "${pkg_path}" != "" ]]; then
            signature_check=`/usr/sbin/pkgutil --check-signature "$pkg_path" | awk /'Developer ID Installer/{ print $5 }'`
            if [[ ${signature_check} = "Oracle" ]]; then
                # Install Oracle Java 8 from the installer package stored inside the disk image
                /usr/sbin/installer -dumplog -verbose -pkg "${pkg_path}" -target "/" > /dev/null 2>&1
        # Clean-up
        # Unmount the Oracle Java 8 disk image from /tmp/java_eight.XXXX
        /usr/bin/hdiutil detach -force "$TMPMOUNT"
        # Remove the /tmp/java_eight.XXXX mountpoint
        /bin/rm -rf "$TMPMOUNT"
        # Remove the downloaded disk image
        /bin/rm -rf "$java_eight_dmg"
        # Remove xml file
        /bin/rm -rf /tmp/au-1.8.0_20.xml
  • 1054 replies
  • October 6, 2015
Thanks Peter !!! :) not re-inventing the wheel is always great!!!!
C
  • February 23, 2016
Hi Peter,
Am trying this - sometimes it shows it runs all the way through but nothing is updated and other times I get an error (see below) any ideas?
Executing Policy Autoupdate Java (Test)...
Running script Autoupdate Java...
Script exit code: 1
Script result: Current version is Java 8 Update 31
Installed main version is 8
Installed minor version is 31
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 1160 100 1160 0 0 3501 0 --:--:-- --:--:-- --:--:-- 3504
Online main: 8
Online minor: 73
100 915 0 915 0 0 4145 0 --:--:-- --:--:-- --:--:-- 4140
100 935 0 935 0 0 3508 0 --:--:-- --:--:-- --:--:-- 3501
2 64.2M 2 1551k 0 0 1402k 0 0:00:46 0:00:01 0:00:45 1402k
6 64.2M 6 4064k 0 0 1928k 0 0:00:34 0:00:02 0:00:32 2507k
8 64.2M 8 5626k 0 0 1802k 0 0:00:36 0:00:03 0:00:33 2021k
11 64.2M 11 7261k 0 0 1769k 0 0:00:37 0:00:04 0:00:33 1904k
13 64.2M 13 9190k 0 0 1800k 0 0:00:36 0:00:05 0:00:31 1909k
17 64.2M 17 11.3M 0 0 1912k 0 0:00:34 0:00:06 0:00:28 2024k
20 64.2M 20 13.3M 0 0 1923k 0 0:00:34 0:00:07 0:00:27 1920k
23 64.2M 23 15.2M 0 0 1919k 0 0:00:34 0:00:08 0:00:26 1991k
26 64.2M 26 17.2M 0 0 1941k 0 0:00:33 0:00:09 0:00:24 2083k
30 64.2M 30 19.3M 0 0 1961k 0 0:00:33 0:00:10 0:00:23 2126k
33 64.2M 33 21.4M 0 0 1974k 0 0:00:33 0:00:11 0:00:22 2049k
37 64.2M 37 23.9M 0 0 2024k 0 0:00:32 0:00:12 0:00:20 2169k
40 64.2M 40 26.3M 0 0 2057k 0 0:00:31 0:00:13 0:00:18 2281k
44 64.2M 44 28.6M 0 0 2077k 0 0:00:31 0:00:14 0:00:17 2323k
48 64.2M 48 30.9M 0 0 2096k 0 0:00:31 0:00:15 0:00:16 2369k
51 64.2M 51 33.1M 0 0 2107k 0 0:00:31 0:00:16 0:00:15 2403k
54 64.2M 54 35.1M 0 0 2104k 0 0:00:31 0:00:17 0:00:14 2297k
59 64.2M 59 38.2M 0 0 2164k 0 0:00:30 0:00:18 0:00:12 2444k
64 64.2M 64 41.5M 0 0 2229k 0 0:00:29 0:00:19 0:00:10 2657k
69 64.2M 69 44.5M 0 0 2268k 0 0:00:28 0:00:20 0:00:08 2788k
72 64.2M 72 46.6M 0 0 2263k 0 0:00:29 0:00:21 0:00:08 2766k
77 64.2M 77 49.5M 0 0 2295k 0 0:00:28 0:00:22 0:00:06 2947k
82 64.2M 82 52.9M 0 0 2347k 0 0:00:28 0:00:23 0:00:05 3009k
87 64.2M 87 56.4M 0 0 2399k 0 0:00:27 0:00:24 0:00:03 3052k
92 64.2M 92 59.6M 0 0 2434k 0 0:00:27 0:00:25 0:00:02 3101k
98 64.2M 98 63.4M 0 0 2487k 0 0:00:26 0:00:26 --:--:-- 3432k
100 64.2M 100 64.2M 0 0 2497k 0 0:00:26 0:00:26 --:--:-- 3558k
hdiutil: attach failed - No such file or directory
davidacland
  • 1811 replies
  • February 23, 2016
Thanks, I was looking for this just the other day. Much appreciated. Saved me a pile of work!!
Wakko
Forum|alt.badge.img+19
  • 86 replies
  • April 1, 2016
Any update form dshumatetaos post. It fails to update, this is the results I'm getting.
Script result: Current version is Java 8 Update 73 build 02
Installed minor version is 73
100 1160 100 1160 0 0 6054 0 --:--:-- --:--:-- --:--:-- 6073
Online main: 8
Online minor: 77
100 935 0 935 0 0 4529 0 --:--:-- --:--:-- --:--:-- 4538
4 64.2M 4 3201k 0 0 3838k 0 0:00:17 --:--:-- 0:00:17 3838k
15 64.2M 15 9.9M 0 0 5580k 0 0:00:11 0:00:01 0:00:10 7034k
24 64.2M 24 15.9M 0 0 5758k 0 0:00:11 0:00:02 0:00:09 6558k
34 64.2M 34 22.0M 0 0 5900k 0 0:00:11 0:00:03 0:00:08 6473k
44 64.2M 44 28.5M 0 0 6058k 0 0:00:10 0:00:04 0:00:06 6520k
54 64.2M 54 34.9M 0 0 6128k 0 0:00:10 0:00:05 0:00:05 6509k
64 64.2M 64 41.4M 0 0 6217k 0 0:00:10 0:00:06 0:00:04 6450k
74 64.2M 74 47.6M 0 0 6234k 0 0:00:10 0:00:07 0:00:03 6503k
83 64.2M 83 53.4M 0 0 6200k 0 0:00:10 0:00:08 0:00:02 6430k
92 64.2M 92 59.6M 0 0 6213k 0 0:00:10 0:00:09 0:00:01 6362k
100 64.2M 100 64.2M 0 0 6249k 0 0:00:10 0:00:10 --:--:-- 6398k
/dev/disk4 GUID_partition_scheme /dev/disk4s1 Apple_HFS /private/tmp/java_eight.EJ9s
"disk4" unmounted.
"disk4" ejected.
peterlbk
  • 67 replies
  • April 1, 2016
Hi All, and especially @dshumatetaos and @Echevarria just tested it again with this script and all worked well. Please let me know if this one still gives errors.
#!/bin/sh -x
if [ -f "$plugin" ]
then
    onlineversionmain=`curl http://www.java.com/en/download/manual.jsp | grep "Recommended Version" | awk '{ print $4}'`
    onlineversionmin1=`curl http://www.java.com/en/download/manual.jsp | grep "Recommended Version" | awk '{ print $6}'`
    onlineversionmin=${onlineversionmin1:0:2}
    if [ -z "$currentvermain" ] || [ "$onlineversionmain" -gt "$currentvermain" ]
    then
        installjava=1
    then
        installjava=1
    then
    installjava=1
# Find Download URL
fileURL=`curl http://www.java.com/en/download/manual.jsp | grep "Download Java for Mac OS X" | awk -F """ '{ print $4;exit}'`
then
        # Find the Java installer
        JAVAVOL=`ls /Volumes/ | grep "Java"`
          JAVAAPP=`ls "$TMPMOUNT" | grep "Java"`
          pkg_path=`ls "$TMPMOUNT"/"$JAVAAPP"/Contents/Resources/*Java*.pkg`
        # Check installer certificate
        # Clean-up
  • 46 replies
  • June 16, 2016
Hey @peterloobuyck -- Same issue here as @dshumatetaos and @Echevarria ... I have tried both script versions you have on this site; it seems to try and do "stuff" but the version does not change after the script runs:
Checking for policies triggered by "java" for user "ryan.s"...
Executing Policy Java (JRE) Updater
Mounting NA-US-CA-Fremont-Office to /Volumes/casper...
Getting package details from https://jss.teslamotors.com:8443/...
Uninstalling...
    Looking for Applications...
    Deleting files...
Uninstalled oracle_java_jre_7u67.dmg.
Uninstalling...
    Deleting files...
Uninstalled oracle_java_jre_8u65.dmg.
Running script App_JavaJRE-autoupd...
Script exit code: 0
Script result: ++ sw_vers -productVersion
++ awk -F. '{print $2}'
+ osvers=11
+ plugin='/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Info.plist'
+ '[' -f '/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Info.plist' ']'
+ echo 'No java installed, let'''s install'
+ installjava=1
++ curl http://www.java.com/en/download/manual.jsp
++ grep 'Download Java for Mac OS X'
++ awk -F '"' '{ print $4;exit}'
100 23151  100 23151    0     0   294k      0 --:--:-- --:--:-- --:--:--  297k
+ fileURL='http://javadl.oracle.com/webapps/download/AutoDL?BundleId=207766'
+ java_eight_dmg=/tmp/java_eight.dmg
+ [[ 11 -lt 7 ]]
+ '[' 1 = 1 ']'
+ echo 'Start installing Java'
+ [[ 11 -ge 7 ]]
+ /usr/bin/curl --retry 3 -Lo /tmp/java_eight.dmg 'http://javadl.oracle.com/webapps/download/AutoDL?BundleId=207766'
100   755    0   755    0     0   1233      0 --:--:-- --:--:-- --:--:--  1235
100 64.2M  100 64.2M    0     0  24.1M      0  0:00:02  0:00:02 --:--:-- 33.6M
++ /usr/bin/mktemp -d /tmp/java_eight.XXXX
+ TMPMOUNT=/tmp/java_eight.TjzG
+ hdiutil attach /tmp/java_eight.dmg -mountpoint /tmp/java_eight.TjzG -nobrowse -noverify -noautoopen
/dev/disk3              GUID_partition_scheme
/dev/disk3s1            Apple_HFS                       /private/tmp/java_eight.TjzG
++ ls /Volumes/
++ grep Java
+ JAVAVOL=
++ ls /tmp/java_eight.TjzG
++ grep Java
+ JAVAAPP='Java 8 Update 91.app'
++ ls '/tmp/java_eight.TjzG/Java 8 Update 91.app/Contents/Resources/JavaAppletPlugin.pkg'
+ pkg_path='/tmp/java_eight.TjzG/Java 8 Update 91.app/Contents/Resources/JavaAppletPlugin.pkg'
+ [[ /tmp/java_eight.TjzG/Java 8 Update 91.app/Contents/Resources/JavaAppletPlugin.pkg != '' ]]
++ /usr/sbin/pkgutil --check-signature '/tmp/java_eight.TjzG/Java 8 Update 91.app/Contents/Resources/JavaAppletPlugin.pkg'
++ awk '/Developer ID Installer/{ print $5 }'
+ signature_check=Oracle
+ [[ Oracle = O
acle ]]
+ /usr/sbin/installer -dumplog -verbose -pkg '/tmp/java_eight.TjzG/Java 8 Update 91.app/Contents/Resources/JavaAppletPlugin.pkg' -target /
+ /usr/bin/hdiutil detach -force /tmp/java_eight.TjzG
"disk3" unmounted.
"disk3" ejected.
+ /bin/rm -rf /tmp/java_eight.TjzG
+ /bin/rm -rf /tmp/java_eight.dmg
Unmounting file server...
Looking at my Casper inventory: Java 8 Update 60.app Java 8 Update 60 build 27 /Users/ryan.s/Library/Application Support/Java/Java 1.8.60.27/Java 8 Update 60.app No
I'm trying to debug, can I cannot seem to find anything broken...
peterlbk
  • 67 replies
  • June 20, 2016
Hi guys, @ryan.s @davidacland @Echevarria
Seems you're right, Oracle played with its own installer app.
Can you test the script underneath? I made some changes and tests in my testlab seems to be ok...
#!/bin/bash -e
if [ -f "$plugin" ]
then
    then
        installjava=1
    then
        installjava=1
    then
    installjava=1
then
        TMPMOUNT=`/usr/bin/mktemp -d /Volumes/java_eight.XXXX`
        # Mount the latest Oracle Java disk image to /tmp/java_eight.XXXX mountpoint
        if [[ -e "$(/usr/bin/find $TMPMOUNT -name *Java*.pkg)" ]]; then
            pkg_path=`/usr/bin/find $TMPMOUNT -name *Java*.pkg`
        elif [[ -e "$(/usr/bin/find $TMPMOUNT -name *Java*.mpkg)" ]]; then
            pkg_path=`/usr/bin/find $TMPMOUNT -name *Java*.mpkg`
                echo "installing Java from ${pkg_path}..."
        # Clean-up
        # Unmount the disk image from /tmp/java_eight.XXXX
        # Remove xml file
davidacland
  • 1811 replies
  • June 20, 2016
Thanks, works ok for me.
  • 288 replies
  • July 20, 2016
  • 288 replies
  • July 21, 2016
The current script is erroring ever since Oracle released a 3 digit version number.
The $onlineversionmin variable is returning 10 instead of 101. $onlineversion2 also returning 1.8.0_10 instead of 1.8.0_101
While using variables like the below work for two digit version numbers, they break when Oracle released version 101. onlineversion2=${onlineversion1:50:9} onlineversionmain=${onlineversion2:2:1}
I'm making some modifications on the script to allow support for both two and three digit version numbers.
I changed it so that if Java isn't installed, it exits. (we didn't want users in our environment to get java installed if they didn't have it).
Also added functionality to remove the /tmp/au-1.8.0_20.xml once the script ran regardless if it installs or not. Previously it removed if the software needed to be updated.
# This script downloads and installs the latest Oracle Java 8 for Macs
if [ -f "$plugin" ]
then
    currentvermain=`/usr/bin/defaults read "/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Info.plist" CFBundleShortVersionString | awk '{print $2}'`
    currentvermin=`/usr/bin/defaults read "/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Info.plist" CFBundleShortVersionString | awk '{print $4}'`
    onlineversion1=`cat /tmp/au-1.8.0_20.xml | awk -F " /enclosure/'{print $(NF-1)}' | grep -oE 'd.d.{1,2}d_d{1,3}'`
    onlineversionmain=`cat /tmp/au-1.8.0_20.xml | awk -F " /enclosure/'{print $(NF-1)}' | grep -oE 'd.d.{1,2}d_d{1,3}' | cut -d '.' -f2`
    onlineversionmin=`cat /tmp/au-1.8.0_20.xml | awk -F " /enclosure/'{print $(NF-1)}' | grep -oE 'd.d.{1,2}d_d{1,3}' | cut -d "_" -f 2`
    then
        echo "Java version is newer than installed version."
        installjava=1
    then
        installjava=1
    then
        # Remove xml file
    echo "No java installed, exit"
    installjava=0
    # Remove xml file
then
        # Clean-up
        # Remove xml file
peterlbk
  • 67 replies
  • July 27, 2016
Hi guys @bbot , since Oracle changes things a lot, I changed the script a bit. I now read the manual download page and grab versions. New script underneath
if [ -f "$plugin" ]
then
    onlineversionmin1=`curl http://www.java.com/en/download/manual.jsp | grep "Recommended Version" | awk '{ print $6}' | awk -F "<" '{ print $1}'`
    onlineversionmin=${onlineversionmin1:0:3}
    then
        installjava=1
    then
        installjava=1
    then
    installjava=1
# Find Download URL
  • 401 replies
  • August 10, 2016
No chance you've got something similar for the Java JDK? ;-)
  • 34 replies
  • August 11, 2016
@peterloobuyck
Hey buddy i wanted to see if any of the Java update scripts listed were able to address the issue with the policy completing successfully but the version is still the same. I ran this script and the following results took place but the update didn't happen:
Executing Policy Java Installation update
Running script New Java Update Script...
Script exit code: 0
100 1167 100 1167 0 0 2111 0 --:--:-- --:--:-- --:--:-- 2110
Online main: 8
Online minor: 10
  • 288 replies
  • August 11, 2016
@bjones If you look at my post above, the issue is that the script isn't finding the new version number 101. As you can see in your log, it thinks the version number is Main 8, Minor 10, which is why the script is exiting.
See below in bold for what it should return.
Script result: Current version is Java 8 Update 71 build 15
Installed minor version is 71
100 1167 100 1167 0 0 5926 0 --:--:-- --:--:-- --:--:-- 5954
Online main: 8
Online minor: 101
100 945 0 945 0 0 5708 0 --:--:-- --:--:-- --:--:-- 5762
7 64.3M 7 4753k 0 0 4035k 0 0:00:16 0:00:01 0:00:15 4758k
23 64.3M 23 14.9M 0 0 7008k 0 0:00:09 0:00:02 0:00:07 7638k
40 64.3M 40 26.1M 0 0 8417k 0 0:00:07 0:00:03 0:00:04 8921k
58 64.3M 58 37.3M 0 0 9152k 0 0:00:07 0:00:04 0:00:03 9564k
73 64.3M 73 47.0M 0 0 9313k 0 0:00:07 0:00:05 0:00:02 9648k
90 64.3M 90 58.3M 0 0 9666k 0 0:00:06 0:00:06 --:--:-- 10.7M
100 64.3M 100 64.3M 0 0 9810k 0 0:00:06 0:00:06 --:--:-- 10.8M
/dev/disk2 GUID_partition_scheme
/dev/disk2s1 Apple_HFS /Volumes/java_eight.DTf1
installing Java from /Volumes/java_eight.DTf1/Java 8 Update 101.app/Contents/Resources/JavaAppletPlugin.pkg...
"disk2" unmounted.
"disk2" ejected.
Try running my modified script above, it handles both 2 and 3 digit version numbers.
@peterloobuyck Have you modified your script for the new 3 digit version numbers?
peterlbk
  • 67 replies
  • August 12, 2016
@bjones @bbot Yep!
if [ -f "$plugin" ]
then
    then
        installjava=1
    then
        installjava=1
    then
    installjava=1
# Find Download URL
  • 14 replies
  • August 31, 2016
Made minor modification to lines 11, 13, and 18 to grab the word rather than a specific number of characters. Should keep this from needing a change (or breaking) when version numbers increase or decrease in digits.
if [ -f "$plugin" ]
then
    currentvermain=$(echo $currentver | awk '{ print $2}')
    currentvermin=$(echo $currentver | awk '{ print $4}')
    onlineversionmin=$(echo $onlineversionmin1 | awk '{ print $1}')
    then
        installjava=1
    then
        installjava=1
    then
    installjava=1
# Find Download URL
then
        # Clean-up
        # Remove xml file
  • 401 replies
  • November 8, 2016
@Rocky I'm getting an error in line 20 when it tries to get/use (?) the minor version.
Online minor:
./test.sh: line 20: [: : integer expression expected
I'm running Java 8 Update 111 build 14 on my test machine.
 Current version is Java 8 Update 111 build 14
Installed minor version is 111
peterlbk
  • 67 replies
  • November 8, 2016
@cwaldrip and @Rocky
Did some cleaning up. You should be able to use this one... Oracle did some changes on their website...
if [ -f "$plugin" ]
then
    currentvermin=${currentver:14:3}
    onlineversionmain=`curl -L http://www.java.com/en/download/manual.jsp | grep "Recommended Version" | awk '{ print $4}'`
    onlineversionmin1=`curl -L http://www.java.com/en/download/manual.jsp | grep "Recommended Version" | awk '{ print $6}' | awk -F "<" '{ print $1}'`
    if [ -z "${currentvermain}" ] || [ "${onlineversionmain}" -gt "${currentvermain}" ]
    then
        installjava=1
    if [ "${onlineversionmain}" = "${currentvermain}" ] && [ "${onlineversionmin}" -gt "${currentvermin}" ]
    then
        installjava=1
    if [ "${onlineversionmain}" = "${currentvermain}" ] && [ "${onlineversionmin}" = "${currentvermin}" ]
    then
    installjava=1
# Find Download URL
fileURL=`curl -L http://www.java.com/en/download/manual.jsp | grep "Download Java for Mac OS X" | awk -F """ '{ print $4;exit}'`
then
        # Clean-up
        # Remove xml file
  • 401 replies
  • November 8, 2016
Yep, that did it. Thanks @peterloobuyck !
  • 83 replies
  • January 18, 2017
Hmm, I tried the script posted on 11/8/16, and got this:
Executing Policy Install Java
Running script Install Java.sh...
Script exit code: 0
Script result: No java installed, let's install
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
100 36 100 36 0 0 9 0 0:00:04 0:00:03 0:00:01 16
curl: (3) malformed
hdiutil: detach failed - No such file or directory
Any suggestions?
peterlbk
  • 67 replies
  • January 18, 2017
@stevenjklein Hi Steven, just ran another test and all runs smooth..
What version of MacOS did you run it on?
And just to be sure, I attach the latest version once more.
if [ -f "$plugin" ]
then
    then
        installjava=1
    then
        installjava=1
    then
    installjava=1
# Find Download URL
then
        # Clean-up
        # Remove xml file
  • 83 replies
  • January 18, 2017
@peterloobuyck : Hi Peter. The target machine is running 10.12.2. I note that Oracle released a Java update in the last day or two, but I don't know if that's relevant.
peterlbk
  • 67 replies
  • January 18, 2017
@stevenjklein hi steven, i tested it on a similar machine. It should work even after the update. You're not behind a proxy are you?
  • 83 replies
  • January 18, 2017
@peterloobuyck : Okay, I decided to save it as a shell script, make it executable, and run it on the target machine.
It refused to run.
I checked, and discovered it had Mac line breaks (CR instead of LF). (I know, rookie mistake!)
I used this nifty bit of PERL to fix it:
perl -pi -e 's/
/g' install_Java.sh
And now it works.
Thanks for your help!
peterlbk
  • 67 replies
  • January 19, 2017
@stevenjklein Hi Steven, glad it's all working now!
Cookie policy
Cookie settings
