Available Network Interface Script Help
jhbush
  • 539 replies
I'm trying to tidy up my search domain script by only grabbing the available network interfaces. If I use my existing one from my first boot script I receive errors due the fact that not all of them are present. It doesn't effect the search domain being applied, but the end user sees the error through self service attempting to run it multiple times. Anyway here's what I have so far. I can't figure out how to escape the space in between say Display Ethernet or to keep Wi-Fi intact.
declare -x SearchDomains="my.domain.com"
export devlist="$(networksetup -listnetworkserviceorder | grep Hardware |
    sed -e 's/^(H.*rt: (.*), Device: (.*))/1/'
        -e 's/[()*#]//g' -e 's/[ -]/_/g')"
echo My device list:
for dev in ${devlist}; do /usr/sbin/networksetup -setsearchdomains ${dev} ${SearchDomains}; done
echo
Best answer by andyinindy
I think I have it:
declare -x SearchDomains="butler.edu"
IFS=$'
devlist=(`networksetup -listnetworkserviceorder | grep Hardware | sed -e 's/^(H.*rt: (.*), Device: (.*))/1/' -e 's/[()*#]//g' | uniq`)
tLen=${#devlist[@]}
for (( i=0; i<${tLen}; i++ ));
do
/usr/sbin/networksetup -setsearchdomains "${devlist[$i]}" $SearchDomains
done
echo
You might need to fool around with the echo stuff to get it to print out what you want, but otherwise it seems to work.
--Andy
  • 238 replies
  • May 2, 2013
Does this accomplish what you had in mind:
export devlist="$(networksetup -listnetworkserviceorder | grep Hardware | sed -e 's/^(H.*rt: (.*), Device: (.*))/1/' -e 's/[()*#]//g' | sed 's/$/,/g')"
export devarray=(`echo $devlist | tr "," "
" | uniq`)
for i in ${devarray[@]}; do /usr/sbin/networksetup -setsearchdomains $i $SearchDomains; done
echo
jhbush
  • 539 replies
  • May 2, 2013
Andy, it's close but the problem still seems to be with how networksetup accepts the interface information. If I echo out devlist the names of the interfaces look fine on both scripts. It's only when you try and send that to network setup do get the line breaks and the error. Thank you for your help.
My device list:Bluetooth DUN, Thunderbolt Ethernet, Display Ethernet, Display Ethernet, Display Ethernet, Display FireWire, Display FireWire, Display FireWire, Wi-Fi, Bluetooth PAN,
Bluetooth is not a recognized network service.
** Error: The parameters were not valid.
DUN is not a recognized network service.
Thunderbolt is not a recognized network service.
Ethernet is not a recognized network service.
Display is not a recognized network service.
FireWire is not a recognized network service.
** Error: Unable to commit changes to network database.
PAN is not a recognized network service.
  • 238 replies
  • May 2, 2013
I assume that you have tried putting the ${dev} (or the $i in my script) into double quotes?
do /usr/sbin/networksetup -setsearchdomains "${dev}" ${SearchDomains}
jhbush
  • 539 replies
  • May 2, 2013
I did but I still get the same line returns on the input. pmbuko has this on his site which grabs the primary only.
mainInt=$(networksetup -listnetworkserviceorder |
    awk -F'\\) ' '/(1)/ {print $2}')
    networksetup -setsearchdomains "$mainInt" sub.domain.com domain.com
  • 238 replies
  • May 3, 2013
I think I have it:
IFS=$'
tLen=${#devlist[@]}
do
done
echo
--Andy
jhbush
  • 539 replies
  • May 3, 2013
Andy, thank you so much for figuring this out. The one last thing is how do you get a new line inserted? I have 12 search domains. When I run this it puts them all one line.
  • 238 replies
  • May 3, 2013
If you know what the searchdomains will be then you can do away with the $SearchDomains variable entirely and simply add them like so:
/usr/sbin/networksetup -setsearchdomains "${devlist[$i]}" butler.edu stanford.edu unc.edu
HTH,
--Andy
jhbush
  • 539 replies
  • May 3, 2013
Andy, thank you. I owe you many beers at JNUC.
IFS=$'
tLen=${#devlist[@]}
do
/usr/sbin/networksetup -setsearchdomains "${devlist[$i]}" your1.domain.com your2.domain.com your3.domain.com your4.domain.com
done
echo
  • 238 replies
  • May 3, 2013
Glad I could help! Looking forward to quaffing some Surly at next year's JNUC (assuming it's in MN like last time). I could also dig on some Elysian, if I ever make it out to Seattle again :)
  • 134 replies
  • January 9, 2015
andyinindy / jhbush1973
Thanks for this. I had been using one script per net interface.
I like this as it will assign the specified search domains to any network interface, even if it is not presently active. thanks again, john
Cookie policy
Cookie settings
