Big Sur with F5 Big IP Edge client and WSS Agent?
brianmcbride99
Contributor
I'm wondering if anyone else is running the F5 Big IP Edge VPN client and the Broadcom(symantec) WSS agent on macOS 11?
We have issues with DNS resolution completely cutting out randomly. The only resolution is to either disconnect/reconnect the big ip VPN connection or (sometime) Reconnect the WSS agent connection
Big IP Edge v7212
WSS v7.3.5
Just curious if there is anyone else here who is running both products in macOS 11 and possibly seeing the same issues?
0 REPLIES 0
