In my environment I have a brand new machine come in. I immediately netboot it and image with a configuration that consists of all the apps to lay over the top of the installed OS that came with the machine. I have some applications install and then it binds the machine to AD and runs the casper quick add package one more time at the end. However, it will never bind to AD and comes up with no way for me to get in. It does not add the machine to the JSS.
Here is the interesting part, once I try to netboot and then erase drive and add in OS install part all seems to work fine and it gets added to JSS. Now if I reimage the machine back to factory specs and remove from JSS and try the same scenario as above all seems to work fine. The JSS has the object removed and the hardrive is wiped and replaced with image captured (factory) so it is back to the way it was from factory.
Any one had any luck or issues with slapping down applications and adding a brand new out of box Mac to the JSS that has never seen the JSS? I don't use prestage imaging at all and don't really need to in my environment.
Any help or thoughts are appreciated.
