- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 07-17-2014 09:29 AM
I'm trying to figure out how I can call a script as one exits. I do not want to run the script inside of the other script. I want it to call the next one as it exits. I'm not sure if this can be done. Here is a better representation of it.
First Script runs
Exits - Calls Second Script
Second Script runs
exits - Calls Third
etc
etc
etc
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 07-17-2014 09:31 AM
Ouch, just figured it out, I will load a launch daemon just before exiting. This daemon will call the script.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 07-18-2014 10:17 AM
You could also use "trap" in each script which is a shell builtin.
# Define a function to call for the trap
OnExit() {
run script
# or execute policy
# Tell the script to call the function when an exit signal occurs
trap OnExit exit
# Do the script's stuff
do a command
do a command
# Now on exit it will always trigger the above function
I have more fleshed out examples in a post I did here:
http://bryson3gps.wordpress.com/2013/11/10/bash-favorites/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 07-19-2014 09:38 AM
Adding an ampersand at the end of a line in a script will run that process in the background and should allow your new forked process to continue although your script is exited.
run stuff in your script
sh /path/to/another/script.sh &
A downside to this method is you can't easily return any results to the JSS from the forked process.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
OnExit() {
run script
# or execute policy
trap OnExit exit
do a command
do a command
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-16-2015 03:51 PM
Did something change with Bash or the way the JSS runs scripts? I cannot for the life of me get a thread to fork or a trap to execute on exit without Casper waiting for it to complete while I am trying to schedule a restart, which means the policy log never gets uploaded to the JSS (the restart interrupts it). My tests work fine outside of Casper.
I am thinking a launchdaemon is my only option. I would use a policy-driven restart, except the restart occurs even if the policy fails, which is very bad for my needs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-16-2015 04:11 PM
I moved a lot of postinstall stuff into running out of launchdaemon just for that express reason that the casper policy finishes successfully, and what I need to happen at the back end finishes. I usually have my recon built in the postinstall if I need the database updated as well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-16-2015 04:35 PM
Yeah, I just built a launchdaemon to run a script for my reboot, and that solved it.
