I have deployed Splashbuddy in a test environment. When a computer enrolls, I get the splashbuddy with all my apps listed with the correct icons and presentation however, the only feedback I get is "We are preparing your mac" message. there is no completions on the applications and I have no feedback to present to the user.
Has anybody experienced this?
I suspect it has to do with packageName in the ApplicationsArray. The Kickstart shows PKG files. I am using DMGs .
My package names on Jamf are ie) . googleFileStream-25.102.133.222.dmg and I just put googleFileStream in the packageName spot.
