Posted on 02-06-2012 06:41 AM
Hi all,
Anyone experience or know why when I try to push something with Casper Remote 8.4 it just takes forever? If I do as a policy from the JSS, whatever I install is done in record time.
My JSS is 8.4 on server 10.6.8. Clients some 10.6.8, some 10.7.3. All client jamf binaries are at 8.4
Solved! Go to Solution.
Posted on 02-06-2012 08:18 AM
Solved it..
Had to shut off HTTP downloads of the Distribution Point in the JSS!!
Just curious... why bother having HTTP if it is that slow?
Solved it..
