Casper Remote issues
Kyuubi
Contributor
I've got a Mac Mini that i use for package building and other things. Recently, when i use Casper Remote to run policies on a test machine it gets stuck on SSH authentication and goes no further. I've used Casper Remote on another machine, trying connect to the same test machine and it goes thru with no issues. I've checked on JAMF Nation and found articles which put the crux of the problem on the client. Telling me to remove the JAMF framework and re-enroll. That is clearly not the issue here. I've tried removing the com.jamfsoftware.casperremote.plist but still can't get past authentication. Any ideas?
1 REPLY 1
Cornoir
Contributor II
Might be the JSS certificate you have installed in Keychain Acccess as I had a similar issue and had to remove the JSS cert from my Mac and then reenroll my Mac to the JSS, then I was able to use Casper Remote without issues.
