Change Screenshot Location Script Help
  • July 22, 2021
  • 1 view
I'm having trouble getting this script working. It test successfully when running the script locally on my machine, but when run through the JSS the change default location isn't working, screenshots still go to Desktop, and the script throws no errors.
Any suggestions?
#!/bin/sh loggedInUser=$( ls -l /dev/console | awk '{print $3}' ) sudo -u $loggedInUser defaults write com.apple.screencapture location ~/Downloads mv /Users/$loggedInUser/Desktop/Screen* /Users/$loggedInUser/Downloads
Best answer by skeenan07
Try using the full path when writing to com.apple.screencapture.
sudo -u $loggedInUser defaults write com.apple.screencapture location /Users/$loggedInUser/Downloads
1 reply
skeenan07
  • 34 replies
  • July 22, 2021
Cookie policy
Cookie settings
