Change Wireless Network Script
jszaszvari
New Contributor III
New Contributor III
Hi All
I'm using the Change wireless network script provided in the resource kit and it works great, except on roughly ¼ of machines its running on, it fails and returns
" Error: -3924 Invalid PMK** Error: Error obtaining wireless information. "
But the same script works perfectly on other MacBooks with the same OS and hardware revision.
I did a quick Google but could not find anything.
Has anyone seem this before?
Regards,
John
John Szaszvari
Network Manager | Monte Sant' Angelo Mercy College
02-9409-6281 | jszaszvari at monte.nsw.edu.au | 128 Miller St, North Sydney
3 REPLIES 3
jarednichols
Honored Contributor
PMK is Pairwise Master Key. It's used in 802.1x authentication. Hope that will put you in the right direction…
j
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
jszaszvari
New Contributor III
New Contributor III
Hmmm Interesting, We are not using that here for our Wireless Security.
Will do some research
Thanks for that
tlarkin
Honored Contributor
what script are you using, can you post the code?
