Checksum for Jamf Pro 10.33 Linux
  • October 27, 2021
  • 7 views
I am attempting to verify my download of 10.33 for Linux.
I cannot match the posted checksum. 0b89f2945f7df906fee4a3d2235670c2fb774cb15212a1591b533737cda2aff4
Can anyone confirm that the posted checksum is correct?
If correct, what tool did you use? shasum -a 256?
  • November 6, 2021
Yes that checksum you posted is correct for Linux.
sha256sum is probably what you're looking to invoke on linux rather than shasum -a 256 which works on macOS.
Also, you need to run the checksum against the compressed .zip file rather than the .run file.
Hope that helps
  • November 9, 2021
Thanks for your reply ithangdang.
Once the download is complete, I have "jamfproinstaller.run" and nothing else.
Will try sha256sum jamfproinstaller.run on a Linux machine.
  • November 9, 2021
Hope that helps
Same result on Linux box -- checksum not equal to what is posted on download page.
Tech support advised me to go ahead with install - so far so good - 10.33 is running fine
Thanks for the help
