Composer and recon not starting
  • September 30, 2014
  • 2 views
When I attempt to launch Composer or Recon I am getting the following:
“Composer.app” can’t be opened because the identity of the developer cannot be confirmed.
“Recon.app” can’t be opened because the identity of the developer cannot be confirmed.
This is the latest version 9.51 downloaded and installed from the Casper Suite 9.51 DMG. All of the other apps in the suite work fine.
Has anyone else seen this? I can get past it by changing the Allow apps to allow all but I should not need to. I have not needed to previously.
1 reply
Yeah. I just ctrl clicked and choose "open". Then you can bypass it and it won't ask again.
