Composer OS Package and Fusion Drive
applesupport-ne
New Contributor III
I've customized a mac image and now I'm in the middle of capturing that image from composer. The issue i'm having is, I don't know which partitions to choose. I see Macintosh HD, Recovery HD and Boot OS X. I can only select two out of three. Thank you in advance. The is for 10.1154e9e2ecd1a141b1aa1980564874003e
6 REPLIES 6
joecurrin
New Contributor III
This will save you more time and hassle than you realize.
https://github.com/MagerValp/AutoDMG
mpermann
Valued Contributor II
@NGKF You could just select the Macintosh HD volume alone if you don't need the recovery partition. Otherwise you should select Macintosh HD and Recovery HD. But I would second what @joecurrin stated, you would be much happier if you used AutoDMG to create a never booted base OS. It will give you the recovery partition without any extra work.
calumhunter
Valued Contributor
monolithic images are bad mmmkay
autoDMG for base images, everything else via scripts/packages
faster to update individual apps/settings, easily repeatable, easily audited
dferrara
Contributor II
@NGKF If you truly need a monolithic image, you'll probably want to rebuild it on a standard drive (not Fusion). What you are seeing here is a list of partitions that Core Storage uses to make a hybrid drive. Composer wasn't really intended for hybrid drives, so unpredictable results are likely.
applesupport-ne
New Contributor III
Thanks guys, I'm new to this so I figure the best thing to do is just ask.
applesupport-ne
New Contributor III
autoDMG!!!! it is :)
