Posted on 03-18-2014 04:25 PM
Hi all. I am trying to import 11 Certs, 3 root and 8 intermediate certs. When I create a config profile for this, it installs the certs to the login keychain. I am creating the CP as a computer level configuration.
I have tried to script this but run into issues as well.
If i run the script locally, it will install the certificates perfectly. I use this this command for each cert:
/usr/bin/security add-trusted-cert -d -r trustAsRoot -k /Library/Keychains/System.keychain "location"
The way I have been trying this via profile is:
a) package all the certs into /Library/Application Support/JAMF/Keychain and drop them to the location via DMG/Composer.
b) script runs after and installs the certificates.(This is where the problem lies, i get a "error reading file path/to/file" error message.The certs have permissions set to everyone = read.
Any thoughts or input?
Thanks.
Posted on 03-18-2014 06:34 PM
is the script running as root?
Posted on 03-19-2014 08:00 AM
I use the script method you mentioned. I built a package that drops the individual cert files into a temp folder then installs each cert in that temp folder via a postflight script. It works like a charm.
I am curious, what is the reasoning behind step A where you pack the certs into a keychain rather than just installing the loose cert files?
Posted on 03-19-2014 03:13 PM
i've done the same also, i usually just put them into /Users/Shared and then remove them at the end of the script.
You could also put them into /tmp
Posted on 03-20-2014 08:49 AM
This is what I use as a post flight script. Works every time.
## postflight
## Not supported for flat packages.
pathToScript=$0
pathToPackage=$1
targetLocation=$2
targetVolume=$3
security add-trusted-cert -d -r trustRoot -k "/Library/Keychains/System.keychain" "/private/tmp/certificates/rootca.cer"
security add-trusted-cert -d -r trustRoot -k "/Library/Keychains/System.keychain" "/private/tmp/certificates/CARoot.cer"
security add-trusted-cert -d -r trustAsRoot -k "/Library/Keychains/System.keychain" "/private/tmp/certificates/SubCA01.cer"
security add-trusted-cert -d -r trustAsRoot -k "/Library/Keychains/System.keychain" "/private/tmp/certificates/subca02.cer"
security add-trusted-cert -d -r trustRoot -k "/Library/Keychains/System.keychain" "/private/tmp/certificates/Web Gateway Root Certificate.cer"
security add-trusted-cert -d -r trustAsRoot -k "/Library/Keychains/System.keychain" "/private/tmp/certificates/wifi.cer"
rm -rf "/private/tmp/certificates"
exit 0 ## Success
exit 1 ## Failure
