Posted on 04-15-2013 01:21 PM
Before I start building a second OS configuration, I wanted to confirm that my iMac 2013 10.8.3 DMG will not work for a Macbook Air Configuration. I know that there are some differences, such as the ethernet over USB, etc, but thought it wouldn't hurt to ask; we just got our first set of MBAs in.
Solved! Go to Solution.
Posted on 04-15-2013 02:29 PM
It should work if you remove the /Library/Preferences/SystemConfiguration/preferences.plist and NetworkInterfaces.plist files... then script any network preferences to take place at reboot.
Posted on 04-15-2013 01:42 PM
If you do a straight clone from an iMac to an image then there's a chance of it not working.
If you make a never before booted image with InstaDMG and the "Install OS X Mountain Lion" app, it will work.
Posted on 04-15-2013 11:43 PM
InstaDMG all the way!
Posted on 04-16-2013 04:52 AM
10.8.3 unified the builds as far as I've seen. Just update both the imac and the MB Air to 10.8.3 and check the build number. If it's the same then you just have to do what Andrew suggested above.
Gabe Shackney
Princeton Public Schools
Posted on 04-16-2013 05:20 AM
Thank you for the advice!
Posted on 04-16-2013 05:46 AM
What Gabe said off the unified nuild, i have imaged iMacs,Macbooks,Macbook Pros and Airs
Go for it
Posted on 04-16-2013 06:20 AM
Unified builds here, after trashing the aforementioned SystemConfiguration plists.
