Connecting AD/AzureAD to Jamfcloud w/out DMZ
EmDee
New Contributor III
Hello,
I need to connect my Jamfcloud instance to my active directory. I have an azure AD subscription but without using a purpose built DMZ.
What is the easiest/best way to do this?
I have found a guide on MSonline but it does not seem to be completely up to date.
Is the best way doing this through Azure, or by opening ports for JAMF to my on premise AD?
Thankyou,
3 REPLIES 3
Chris
Valued Contributor
For LDAP, the easiest way is to use LDAPS through Azure AD Domain Services.
Here's a great guide
whitebeer
Contributor
my feature request on that topic could also be interessting for you - feature request
ajfunk
Contributor
@whitebeer - i think your feature request is coming in Jamf 10.19
