Connecting Azure AD with Jamf Pro
jdizzo
New Contributor
I'm in the process of trying to connect our Azure AD environment with Jamf Pro. I keep getting "Unable to connect to LDAP Server" when I do a test. I'm new to using Azure so please excuse anything obvious.
Settings configured in Jamf Pro
Directory Service = Microsoft's Active Directory
server and port has IP address with port 636
Certificate is uploaded
Authentication Type = Simple
Distinguished Name = service account and password
Referral Response = Use default from LDAP service
User Wildcards When Searching
7 REPLIES 7
alexjdale
Valued Contributor III
It sounds like you set up the cloud IdP as if it were an on-prem AD instance? That doesn't feel right, but I haven't done this myself. I didn't think this was supported.
That said, you might need to do some work on the AAD side to allow incoming LDAPS: https://docs.microsoft.com/en-us/azure/active-directory-domain-services/tutorial-configure-ldaps
jdizzo
New Contributor
thanks for the tip, looking into that now
jorge_
New Contributor III
Hello there, I am trying to connect to Azure AD LDAP as well, did you get this to work ?
ChewtonTown
New Contributor II
You probably want this - https://docs.microsoft.com/en-us/azure/active-directory/saas-apps/jamfprosamlconnector-tutorial
taz231190
New Contributor III
Hope this helps but when you go to add LDAP do not select Microsoft's Active Directory select configure manually and try use the same details
DBrowning
This is a really good resource to follow: Integrate Azure LDAP to Jamf Pro
mntbighker
New Contributor III
How do I thumbs up this whole discussion? ;-)
