Cups constantly checking for default printer every 5 seconds
tnielsen
Valued Contributor
I'm troubleshooting a printer problem and wondering if any of you could help.
I have reset the printer system and not added any printers. My printer list is completely empty.
When you turn on debug logging, command = cupsctl --debug-logging My /var/log/cups/error_log fills up with the following:
D [27/Mar/2019:16:22:16 -0400] CUPS-Get-Printers
D [27/Mar/2019:16:22:16 -0400] CUPS-Get-Printers client-error-not-found: No destinations added.
D [27/Mar/2019:16:22:16 -0400] [Client 3] Returning IPP client-error-not-found for CUPS-Get-Printers (no URI) from localhost.
D [27/Mar/2019:16:22:16 -0400] [Client 3] Content-Length: 116
D [27/Mar/2019:16:22:16 -0400] [Client 3] cupsdSendHeader: code=200, type="application/ipp", auth_type=0
D [27/Mar/2019:16:22:16 -0400] [Client 3] con->http=0x7fa1df001200
D [27/Mar/2019:16:22:16 -0400] [Client 3] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=116, response=0x7fa1dc500860(IPP_STATE_DATA), pipe_pid=0, file=-1
D [27/Mar/2019:16:22:16 -0400] [Client 3] Writing IPP response, ipp_state=IPP_STATE_DATA, old wused=0, new wused=0
D [27/Mar/2019:16:22:16 -0400] [Client 3] bytes=0, http_state=0, data_remaining=116
D [27/Mar/2019:16:22:16 -0400] [Client 3] Flushing write buffer.
D [27/Mar/2019:16:22:16 -0400] [Client 3] New state is HTTP_STATE_WAITING
D [27/Mar/2019:16:22:16 -0400] [Client 3] Waiting for request.
D [27/Mar/2019:16:22:16 -0400] cupsdSetBusyState: newbusy="Not busy", busy="Active clients"
D [27/Mar/2019:16:22:16 -0400] [Client 3] POST / HTTP/1.1
D [27/Mar/2019:16:22:16 -0400] cupsdSetBusyState: newbusy="Active clients", busy="Not busy"
D [27/Mar/2019:16:22:16 -0400] [Client 3] Read: status=200, state=6
D [27/Mar/2019:16:22:16 -0400] [Client 3] No authentication data provided.
D [27/Mar/2019:16:22:16 -0400] [Client 3] 2.0 CUPS-Get-Default 217
If any of you do this, do you see the same?
0 REPLIES 0
