Posted on
07-14-2020
08:16 AM
- last edited
4 weeks ago
by
kh-richa_mig
Hey there - does anyone else use CyberArk EPM (end point management) to manage admin rights and third party app installations more easily? We're beginning to roll out a test bed in my company, and I'm working on the mac deployment.
CyberArk provides some instructions for deploying here, but I'm struggling with them. It seems to want the zip file deployed as the package, and there is no pkg, but I've never used a zip file as an installer through Jamf. Anyone got this deployed? Or have any insight on using zip files to deploy apps?
Posted on 10-04-2021 05:39 AM
please note the instruction guide you to validate it's a one line config as PDF adds CR in the middle...
Posted on 05-04-2021 09:30 AM
I configured profile per instruction, provided, but keep getting deployment error
Posted on 05-04-2021 11:09 AM
@mhasman - can you please elaborate on which instructions you were utilizing and what the deployment error is you are receiving?
Posted on 05-04-2021 05:02 PM
@brianmcbride99 - I use that Install EPM Agent doc
Posted on 05-04-2021 05:07 PM
@mhasman you will need to utilize the PDF here: https://cyberark-customers.force.com/s/article/EPM-How-to-configure-JAMF-for-EPM-Agent-distribution
It’s only made available after you login to their support portal.
Posted on 05-04-2021 05:25 PM
Posted on 05-04-2021 05:27 PM
Posted on 10-03-2024 03:55 PM
https://community.cyberark.com/s/question/0D52J00008tQnzbSAC/getting-return-code-when-installing-via... we're getting an issue a typical corp using jamf, windwos defender, crowdstrike other macos security tools, I am not a mac person myself any ideas, the var/zzz folder seems to be the issue
