Posted on
10-22-2020
12:12 PM
- last edited on
03-04-2025
06:05 AM
by
kh-richa_mig
Is there a way to fetch the primary user details on to the client machine? maybe using jamf recon? I saw that we can set that value using jamf recon(jamf recon -endUsername <>). Is it possible to get those details as well?
Posted on 10-22-2020 01:09 PM
Not though the Jamf binary. You would need to use the API to pull that information from Jamf Pro.
Posted on 10-23-2020 01:18 AM
Thanks for the reply. Is there any specific reason for that feature not to be implemented?
