Good Morning,
I am building out my Yosemite Workflow, and one of the issues I see is the "Require password after Sleep or Screen Saver" is on by default. I have it in my first run script after imaging, to disable this using the following command.
defaults write com.apple.screensaver askForPassword -int 0
The problem I am having is this is re-enabled when a new user logs in. For labs, this isn't a problem as we have a config profile to manage this. For offices, if I set a config profile to manage this, the user can't enable it if they want to. I am sure I could piece this command out and have it set to run once per user, but I was hoping there was a way to make this permanent for new users. Thoughts?
Joe
