Disable True Tone and Auto Brightness with a script
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on
10-25-2022
11:20 AM
- last edited on
01-08-2024
09:03 AM
by
CalleyO
Blackground :
We deal with lots of designers and video editors at my company and they can't do a proper white balance with True Tone. As far as I know, there is no MDM key to manage this setting.
Solution :
I created an Apple Script (embedded in a bash script) that will open and automatically click the right menus in order to turn off True Tone and Auto Brightness. It only works with an English UI but you'll find a French version on my website. It was written for macOS Monterey and Ventura.
Scripts : disable_truetone_english.sh
Blog post : https://clementine.la/scripts/desactiver-true-tone-par-script/
# Author : https://clementine.la
# Created : 2022-09-09
# Last Modified : 2022-10-24
# Version : 2.0
# Tested with : macOS 12.6 / macOS 13.0
# Read logged in user
loggedInUser=$(scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ { print $3 }')
echo "Hello, I am $loggedInUser"
# Read macOS version
macos=$(sw_vers -productVersion)
# FUNCTIONS #
# Disable True Tone & Auto Brightness
# Doesn't work if you have an external monitor plugged in
truetone_monterey() {
open "/System/Applications/System Preferences.app"
sleep 3
open "/System/Library/PreferencePanes/Displays.prefPane"
sleep 1
sudo -u "$loggedInUser" osascript -e '
activate application "System Preferences"
tell process "System Preferences"
repeat until exists group 1 of window "Displays"
end repeat
if (value of checkbox "Automatically adjust brightness" of group 1 of window "Displays" as boolean) then
click checkbox "Automatically adjust brightness" of group 1 of window "Displays"
end if
if (value of checkbox "True Tone, Automatically adapt display to make colours appear consistent in different ambient lighting conditions." of group 1 of window "Displays" as boolean) then
click checkbox "True Tone, Automatically adapt display to make colours appear consistent in different ambient lighting conditions." of group 1 of window "Displays"
end if
end tell
delay 1.0
quit application "System Preferences"
end tell
truetone_ventura() {
open "/System/Applications/System Settings.app"
sleep 3
sleep 1
activate application "System Settings"
tell process "System Settings"
end repeat
if (value of checkbox 1 of group 2 of scroll area 2 of group 1 of group 2 of splitter group 1 of group 1 of window "Displays" as boolean) then
click checkbox 1 of group 2 of scroll area 2 of group 1 of group 2 of splitter group 1 of group 1 of window "Displays"
end if
if (value of checkbox 2 of group 2 of scroll area 2 of group 1 of group 2 of splitter group 1 of group 1 of window "Displays" as boolean) then
click checkbox 2 of group 2 of scroll area 2 of group 1 of group 2 of splitter group 1 of group 1 of window "Displays"
end if
end tell
delay 1.0
quit application "System Settings"
end tell
# END FUNCTIONS #
if [[ "$macos" == "12."* ]]; then
echo "MONTEREY"
truetone_monterey
elif [[ "$macos" == "13."* ]]; then
echo "VENTURA"
truetone_ventura
echo "UNKNOWN OS"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-09-2022 01:49 PM
I'm getting an error when I run it.
587:594: execution error: System Events got an error: Can’t get checkbox 2 of group 2 of scroll area 2 of group 1 of group 2 of splitter group 1 of group 1 of window "Displays" of process "System Settings". Invalid index. (-1719)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-09-2022 01:54 PM
Worked great on a machine with Auto Brightness and True Tone. Maybe thats the issue my iMac doesn't have True Tone. Thanks for this it's exactly what I needed!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-11-2022 04:46 AM - edited 12-11-2022 04:47 AM
The script is not really robust I admit, it expects the 2 settings in the opened window. If you want to keep True Tone on or if your Mac doesn't support it, you can remove the following lines from the script :
end if
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-03-2023 03:37 PM
Any solution if we have 2 displays running?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-20-2024 11:55 AM
Hi! Thanks for the script! Is there any way I can launch it via Shortcut?
I tried pasting the script or launch it via file (chmod +x), doesn't work
