Posted on 02-04-2015 01:33 PM
We are using Casper 9.61 and running Mac OS 10.9.5. I am trying to figure out a way to disable all notification banners in Mac OS (update notifications, email notifications, etc) to, roughly 1500 laptops. We are also trying to figure out how to disable Mission Control and Spaces. I cannot find anything in Configuration Profiles or Managed Preferences. Any suggestions would be appreciated.
Posted on 02-04-2015 01:44 PM
I have two Self Serivce policies that will enable/disable notification center.
This will kill Notification Center (aka Banners)
sudo defaults write /System/Library/LaunchAgents/com.apple.notificationcenterui KeepAlive -bool False
killall NotificationCenter
This will turn them back on.
sudo defaults write /System/Library/LaunchAgents/com.apple.notificationcenterui KeepAlive -bool True
I'm sure there is something similar you could do for spaces. I haven't messed around with this. Just to note... It could cause problems with any user that wants to view apps in "full screen"
Posted on 02-05-2015 07:56 AM
I did figure something else out as well after I posted this. I can use Composer and tell it to take a "New and Modified Snapshot", change the settings, and then finish the snapshot. It does require a reboot of the computer, but I can create a DMG of that and both of those settings will take effect. Is there a reason that this would be a problem?
Thank you for this option by the way.
Posted on 02-05-2015 08:00 AM
I generally try to avoid that approach, only because I have been burned by unforeseen effects down the road. Doesn't mean your approach is bad... Its just a personal preference thing.
Posted on 03-23-2016 11:14 AM
@andrew This is great. How would you suggest I disable notification banners and badges for one specific application?
Posted on 03-30-2016 07:12 AM
Posted on 03-30-2016 09:42 AM
Posted on 03-30-2016 10:11 AM
@jacob_salmela You're the best! Thanks so much!
Posted on 03-30-2016 10:13 AM
No problem! Mark it as an answer if you found it helpful.
