Disabling Remote Login , Remote Management and Forcing Screen Server
__AMM
New Contributor II
Hi all,
It would be great to receive assistance with Jamf Pro since I am new to it.
I was required by the security team to define the following:
1. Disable Remote Login and don't allow users to activate it
2. Disable Remote Management and don't allow users to activate it
3. Put a screen saver on and require a password afterward
My search for these settings did not yield any results in Configuration Profiles.
Thanks
0 REPLIES 0
