Distribution point reset rsync password
tron_jones
We have had staff turn over and the original password set for rsync to replicated the master DP has been forgotten. We recently re-did all the servers in the other buildings and a new password was created for casperadmin and casperinstall users. Where on the main JSS server is a place to reset or change the password rsync is set to use? The original password was set using the old JSSUtility which no longer exists.
3 REPLIES 3
nessts
Valued Contributor II
I think you want to look under each distribution point in Computer settings, File Share distribtuion points edit each DP.
tron_jones
Went through and made sure all accounts were now using the same password on the server and in the JSS-->File Share DP. Still no replications at night during the scheduled time. I can manually replicate through Casper Admin and that works fine. Here's a log from one. This is the one trying to run at night, yet when you run through Admin you get no log.
2014-10-08 18:00:00 Replicating from master distribution point...
2014-10-08 18:00:02
2014-10-08 18:00:02
2014-10-08 18:00:02 ############################ Replication Result ############################
2014-10-08 18:00:02
2014-10-08 18:00:02 receiving file list ... rsync: opendir "/Volumes/Data/CasperShare/.TemporaryItems/folders.1336596020" failed: Permission denied (13)
rsync: opendir "/Volumes/Data/CasperShare/.TemporaryItems/folders.227262789" failed: Permission denied (13)
rsync: opendir "/Volumes/Data/CasperShare/.TemporaryItems/folders.501" failed: Permission denied (13)
rsync: opendir "/Volumes/Data/CasperShare/.TemporaryItems/folders.502" failed: Permission denied (13)
rsync: opendir "/Volumes/Data/CasperShare/.TemporaryItems/folders.503" failed: Permission denied (13)
done
IO error encountered -- skipping file deletion
donmontalvo
Esteemed Contributor III
Sorry for bringing this thread back to life, but any reason why you're not using a service/function account and RSA keys?
https://donmontalvo.com
