Hello All,
I am testing the install of CS6 with policys. I created two packages to test. 1. CS6 Web prem with the updates installed created with AAMME 3.1 and 2. CS6 Web prem with no updates with AAMME 3.1.
The policys I have in place are: 1st policy to cache, 2nd policy to uninstall cs5 and restart, & 3rd a policy to install from cache
With I push the first PKG (with updates) with the above method I get two policy logs for the computer:
1st stating it was successfully installed
2nd The install failed (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.)
From there I check the console logs and I see errors for indd error code dw023
For the 2nd pkg (no updates) with the above policys method again two policy logs:
I check console no install errors to be found.
Anyone come across this? Any help would be very helpful, Thanks
