EA help - script
  • February 6, 2019
  • 8 replies
  • 15 views
I am beginner in scripting, but managed to find the following and it is working
if [ -d /Library/Updates/041-31306 ]; then
echo "<result>TRUE</result>"
echo "<result>FALSE</result>"
exit
Is there a way to build in another path into the same EA - So both Library1 and library 2 must exist (TRUE/FALSE) - or must I create 2 seperate EA for each?
sharriston
  • February 6, 2019
if [[ -e /Library/Updates/041-31306 && -e /other/file/path ]]; then
I tested on my machine with two dummy files. If both exist it will echo true if one is missing it will echo false. Hope this helps.
  • February 6, 2019
if [[ -d  "/path/to/folder/subfolder1" && -d  "/path/to/folder/subfolder2" ]]; then
  • February 20, 2019
Sorry - just found out that I initially wrote this topic the wrong way.
I want that if Folder1 OR folder2 exist it must be TRUE. I wrote that both folders must exist in the opening post
  • February 20, 2019
@Captainamerica In either example above, change && to || and it should give you the results you're looking for.
The && means 'and' (obviously), and || means 'or'
  • February 20, 2019
Thank you :)
  • February 20, 2019
Maybe a bit off topic. But on the mac I run the above script but the extension attribute still show "false" even the folder is there. If I run the same scipt in coderunner on the mac, it shows true. So code is working
I have of course run a recon and inventory is also updated according to Jamf
Has anyone expierenced that before ?
  • February 20, 2019
What are the paths to the folders exactly? Also, can you post the exact script code you're using?
Forum|alt.badge.img+19
  • February 20, 2019
Try this:
if [[ -d  "/path/to/folder/subfolder1" ]] || [[ -d  "/path/to/folder/subfolder2" ]]; then
