Edge Drag and Drop Upload Issue (with Workaround)
raymondap
Hello all,
I wanted to share something that we ran into in the last week in case it helps another Mac admin. We use Google Workspace and Microsoft Edge as our default browser. Over the last week, we've had multiple reports that drag and drop attachment uploads were becoming "corrupted", but attachments using the file chooser dialog worked just fine. We discovered that since the release of Edge 110.0.1587.41, if a user has "Show all filename extensions" unchecked in their Finder preferences, drag and drop uploads would remove the extension from the file, even if it actually has one. I've confirmed this behavior across multiple sites that utilize drag and drop uploads. Enabling the Finder setting resolves the issue, and we've reported the issue to Microsoft.
Be the first to reply!
Cookie policy
Cookie settings
