Enable and Configure Remote Management?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 06-17-2022 09:06 AM
I know a lot has changed in the last few years, but is there a way to enable and configure Remote Management without having to physically do this on each device?
I know you can use ARD when you are physically at the device to configure the service, and Jamf Pro has a "Enable Remote Desktop" command. However the "Enable Remote Desktop" command does not allow for specifying a specific user and what permissions they have. What I would like to do is:
- Enable Remote Management
- Set "Only these users:"
- Add our Management Account
- Set the permissions
NOTE: We are currently doing User-Initiated Enrollments. We are hoping to have access to ABM in the near future.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-17-2022 10:43 AM - edited 06-17-2022 11:05 AM
I am currently using this script with success, which sounds like what you want to do. I take no credit for writing it. Good luck!
LOCALADMIN="youradminaccount"
kickstart=/System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart
echo "Configuring Remote Management"
if id -u $LOCALADMIN >/dev/null 2>&1; then
echo "Defined local admin account exists"
# Deactivate ARD agent, deny all access
echo "Deactivating ARD agent"
$kickstart -deactivate -configure -access -off
echo "Turning off default AllLocalUsers remote management setting"
defaults write /Library/Preferences/com.apple.RemoteManagement ARD_AllLocalUsers -bool FALSE
# Remove 'naprivs' key from users configured by ARD's -specifiedUSers flag
echo "Removing naprivs key from local users"
RemoteManagementUsers=$(dscl . list /Users naprivs | awk '{print $1}')
for EnabledUser in $RemoteManagementUsers; do
echo "--- naprivs removed from $EnabledUser"
dscl . delete /Users/$EnabledUser naprivs
done
# Turn ARD back on and enable only the specified LOCALADMIN
echo "Reconfiguring ARD for only specified users"
$kickstart -configure -allowAccessFor -specifiedUsers
echo "Setting specified local admin account as sole ARD user"
$kickstart -configure -users $LOCALADMIN -access -on -privs -all
echo "Restarting ARD agent"
$kickstart -activate -restart -agent
echo "--- Remote management reset; user ${LOCALADMIN} configured for access"
echo "--- ERROR: The specified local admin account does not exist."
exit 1
(edited for formatting)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-21-2022 05:17 AM
Thank you! I was able to get things mostly working by scrapping a few things together using that.
