Enable ARD script for 10.8.3
Anyone have a script that is working for 10.8.3. the resource kit script was working but now it is not adding users to the "only these users" box.
Got a modified script to try from someone else, it adds the user but does not set any privileges.
If anyone has any advice or different method of doing the same thing I'd appreciate it.
Forum|alt.badge.img+23
  • 850 replies
  • May 23, 2013
Have you seen Apple's page on configuring ARD?
http://support.apple.com/kb/ht2370
  • 907 replies
  • May 23, 2013
I've got one that I posted here...hopefully this is what you are trying to do...if you have questions let me know...I still actively use a modified version of this script.
https://support.jamfsoftware.com/discussion.html?id=6682
  • 42 replies
  • May 23, 2013
This is working for me, just pasted new options on original from resource kit.
thanks
# Copyright (c) 2010, JAMF Software, LLC.  All rights reserved.
#       Redistribution and use in source and binary forms, with or without
#       modification, are permitted provided that the following conditions are met:
#               * Redistributions of source code must retain the above copyright
#                 notice, this list of conditions and the following disclaimer.
#               * Redistributions in binary form must reproduce the above copyright
#                 notice, this list of conditions and the following disclaimer in the
#                 documentation and/or other materials provided with the distribution.
#               * Neither the name of the JAMF Software, LLC nor the
#                 names of its contributors may be used to endorse or promote products
#                 derived from this software without specific prior written permission.
#       THIS SOFTWARE IS PROVIDED BY JAMF SOFTWARE, LLC "AS IS" AND ANY
#       EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
#       WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
#       DISCLAIMED. IN NO EVENT SHALL JAMF SOFTWARE, LLC BE LIABLE FOR ANY
#       DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
#       (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
#       LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
#       ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
#       (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
#       SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# SUPPORT FOR THIS PROGRAM
#       This program is distributed "as is" by JAMF Software, LLC's Resource Kit team. For more
#       information or support for the Resource Kit, please utilize the following resources:
#               http://list.jamfsoftware.com/mailman/listinfo/resourcekit
#               http://www.jamfsoftware.com/support/resource-kit
#       Please reference our SLA for information regarding support of this application:
#               http://www.jamfsoftware.com/support/resource-kit-sla
# ABOUT THIS PROGRAM
# NAME
#   enableARD.sh -- Enable ARD and Configure Remote Management Settings
# SYNOPSIS
#   sudo enableARD.sh
#   sudo enableARD.sh <mountPoint> <computerName> <currentUsername> <targetUsername>
#   If the $targetUsername parameter is specified (parameter 4), this is the account that will be
#   granted access to ARD.
#   If no parameter is specified for parameter 4, the hardcoded value in the script will be used.
# DESCRIPTION
#   This script enables and configures remote management settings for a user.  There are a number
#   of options that the script is capable of configuring, which should be specified in the privs
#   string.  Please see the kickstart man page for more information.
#   The following options are available in the kickstart application:
#       -DeleteFiles
#       -ControlObserve
#       -TextMessages
#       -ShowObserve
#       -OpenQuitApps
#       -GenerateReports
#       -RestartShutDown
#       -SendFiles
#       -ChangeSettings
#       -ObserveOnly
#       -mask
#   ARD access is granted and priviliges  are assigned to an individual account on computers running
#   Mac OS X 10.3 and later. It can be used with a hardcoded value in the script, or read in as a
#   parameter.  Since the Casper Suite defines the first three parameters as (1) Mount Point,
#   (2) Computer Name and (3) username, we are using the forth parameter ($4) as the passable
#   parameter.  We do not use $3 since it may not match up to the username that we want to grant
#   access for.
# HISTORY
#   Version: 1.1
#   - Created by Tedd Herman on August 5th, 2008
#   - Modified by Nick Amundsen on August 5th, 2008
# DEFINE VARIABLES & READ IN PARAMETERS
# HARDCODED VALUE FOR "USERNAME" IS SET HERE
targetUsername="admin"
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 4 AND, IF SO, ASSIGN TO "USERNAME"
if [ "$4" != "" ] && [ "$targetUsername" == "" ];then
    targetUsername=$4
# DEFINE WHICH PRIVILEGES WILL BE SET FOR THE SPECIFIED USER
privs="-all -agent -DeleteFiles -ControlObserve -TextMessages -OpenQuitApps -GenerateReports -restart -SendFiles -ChangeSettings"
# SCRIPT CONTENTS - DO NOT MODIFY BELOW THIS LINE
if [ "$targetUsername" != "" ]; then
    echo "Enabling Apple Remote Desktop Agent..."
    /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -activate -configure -allowAccessFor -specifiedUsers
    echo "Setting Remote Management Privileges for User: $targetUsername ..."
    /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -configure -access -on -privs $privs -users $targetUsername
    echo "Error:  The parameter 'targetUsername' is blank.  Please specify a user."
  • 51 replies
  • October 3, 2013
For what it's worth another approach is to use ARD Admin to build a custom ARD Client installer i.e. a pkg file. This will when run on clients then set the desired options.
Forum|alt.badge.img+31
  • Employee
  • 920 replies
  • October 3, 2013
You can also use ARD Admin to help you build a kickstart script. I have a post on how to do that available here:
http://derflounder.wordpress.com/2013/03/07/using-apple-remote-desktop-admin-to-help-script-ard-kickstart-options/
Cookie policy
Cookie settings
