Enable Certificate-Based Communication, a few devices fail to recon/inventory
  • June 22, 2012
  • 8 views
Today, I enabled Enable Certificate-Based Communication on our JSS (8.52) and since then a few devices fail to communicate to the server when running "sudo jamf recon" from the command line.
I believe that running "jamf enroll" will fix the issue, but is that the proper fix or is that a big hammer approach?
A week ago I enabled the Extension Attribute (EA) of "Verify Certificate Based Communication". I could create a smart group were the Verify Certificate Based Communication is not "Enabled" and run the jamf enroll command if that fix is acceptable.
1 reply
  • June 22, 2012
Tech. Support had me run
jamf enroll -prompt
on the few I had that behaved this way after applying certs.
