Hi all,
I'm in the process of installing an SSL Wildcard Cert on our server.
I uploaded the cert to Tomcat without issue. I'm able to verify the cert is good. No issue there. I was able to verify that current machines can talk to the JSS, MacOS and iOS. Check-in and recon all fine.
I started with an iPad to test enrollment and hit a snag. At enrollment (cogwheel screen), an error came up saying that it could not correctly map back the cert correctly. Doing some research,I found that I had to get rid of the old Cert Anchor in the pre-stage enrollment area. That appeared to work on the iPads without issue. I was then able to wipe the device and re-enroll. Everything appears to be working fine on the iOS side.
I'm not seeing that luck on the MacOS side. Even with getting rid of the Cert Anchor, I'm seeing an issue at the enrollment screen at system setup. If I hit continue on the cogwheel screen, nothing happens. I get no error message. It will sit there until the machine goes to sleep and want to start over again. I have a ticket in with support currently,
I'll make sure to post an update here once I have it ironed out with support. I just wanted to connect with JAMF Nation to see if you had any ideas for me to try while I wait to hear back.
Thanks in advance!
