Enrollment Issues
  • September 1, 2016
  • 8 views
Hi!
So I decided that I was going to try a new configuration for enrolling out devices. I went to apple configurator and configured a test iPad Mini with the MDM server, a wifi network for enrollment (it removes after one hour, and one app that allows users to download apps assigned to them (we remove the app store). I set up the iPad and it added into the MDM server but, it is not receiving commands. I reset the iPad and I am still having the same issue.
Have you even seen this?
Thanks, Jared
  • September 2, 2016
@jared_f
Are they in a Supervised state?
  • September 3, 2016
@Wheelspinning Yes they were supervised. It ended up being an issue with the link to enroll when setting up.
Thanks.
