Posted on
12-14-2017
04:02 AM
- last edited on
03-04-2025
04:26 AM
by
kh-richa_mig
I updated the SSL certificate and I can install the 2 Casper profiles but once it tries to install the MDM one it shows: network error.
I have all ports opened (since they are all inside the same WLAN) and still not working.
Anyone knows how to solve this?
I have Version 10 and since then I have issues with this
thanks
Carmelo
Posted on 12-14-2017 04:12 AM
Hi @carmelolopez,
We ran into the same issue recently. The we faced is a problem is a change in Jamf Pro 10 and there is currently a product issue (PI-004915) open at Jamf.
Make sure your Jamf Pro server(s) can reach www.apple.com over port 80. That solved our issue.
Posted on 12-14-2017 04:13 AM
Thanks will check this, actually it can access all from inside, but need to check the other way is also valid
best
carmelo
Posted on 12-14-2017 05:03 AM
So i have access from my server to this but still not working
Best
Carmelo
Posted on 12-14-2017 05:05 AM
Would you be able to connect you the iOS device and open console to capture the event in the background? You could use Console.app these days for that. We saw a lot of connection errors when installing the MDM profile.
Posted on 12-15-2017 12:43 AM
I did not see anything on the iPhone logs or Linux Server logs from JAMF
This is the error I get
best
carmelo
