Error running profiles command through terminal
  • October 5, 2015
  • 5 views
  • 288 replies
Hello,
I'm running into an error running a script to install a mobileconfig profile using the /usr/bin/profiles -I -F command. The mobileconfig is configured to pull certificates to connect to our 802-1x authenticated. The error returns "returned 102 (The operation couldn’t be completed. (CPFAccess error 102.))" or "(The 'Active Directory Certificate' payload could not be installed. The certificate request failed.)"
I am able to double click the .mobileconfig file and it works fine 100% of the time.
It seems to be hit or miss. It works for some people and not for others. Sometimes doing a restart of the machine allows it to work.
1 reply
  • 288 replies
  • October 7, 2015
Nevermind. I specified the user using the -U switch and that seemed to have fix it.
Cookie policy
Cookie settings
